Preferred Handle for felling axe
I have a felling axe to re-haft. I haven't had much to do with felling axes to date, so am interested in what people think the best haft for this would be. It is a 3 1/2 pound Ardex. I recognize that this is personal preference, but is there solid reasoning behind:
1) Should it be a straight haft or a curved (fawns foot) haft?
2) For the size of head, what length would you use? I am assuming somewhere between 28" and 36"?
Going to order from House Handles.
36 is full length and suitable for the big boys of 4 lb and up. 26-28 is pulpwood/boys axe category for 1 3/4 - 2 1/2 lb. I don't know how many sizes and lengths are physically available these days but somewhere in between (ie 30-32") strikes me as typical for 3 to 3 1/2 lb. How's about taking a tape measure with you when hefting a few display axes at the local hardware store to see/feel what's most comfortable?
Straight or curved choice hinges entirely on personal preference. By convention and by looks, n. American folks are most familiar with curved but when you look at a big Jersey those somehow can go either way without drawing attention.
Important to consider how big you are, how in shape you are, and where you'll be cutting. 36" is generally too big for what most people cut today, and was actually an uncommon size in a lot of boreal and boreal-mixed forests, Maine for example. It can also be a bit of a hindrance if you're doing anything other than felling in open areas, any sort of limbing or even blazing through tight areas is generally poor with a 36" handle.
28-30" will give you better accuracy, and may help you learn if you haven't done a lot of axe work. Can be a little more dangerous, but if you're established with a boy's axe then it may make your transition to a heavier axe easier. It's quite a jump to 3.5 pounds, 3-3.25 is a little more common when learning.
Anywhere between 28" and 32" would be good depending on your height and physical condition. It's preference and feel really. I'm a big guy, 6'2", and I prefer around 29-31", maybe even a 28". They just feel really good to work with in changing conditions and allow you to be more mobile. One of my old handles is around 28" on a 3.5 pound double-bit, I think that was pretty common. A lot of guys back then would have been smaller too. You'll only really know after some work with it, then you can try a second one a little shorter or longer.
I say straight. It should be better for accuracy while a curved handle may give some power and safety benefit. Something like the Gransfors handles is about the limit of how much curve there can reasonably be. And you can compromise between straight and curved, something like a racing axe handle or even a straight handle with a fawn's foot type of swell to retain your grip.
I'd put a 32" fawns foot on it. Felling work is the most taxing on your grip. A fawns foot makes the work a little easier.
Just a heads up if you decide to go with a straight haft, Curt.. I've ordered 2 straight single bit handles from HH, several months apart. Neither is acceptable, and neither can be made to work. I'm sure they will make it right, I just haven't contacted them yet.. I think the lathe is out of adjustment.. On the other hand, the 8 or 10 curved single bits of various lengths I've ordered over the last year or so have been excellent, and have exceeded my expectations!
Tennessee Hickory Products has a retail website now. You can order singles or small quantities from there. It used to be called Hickory Handle Store but they've changed the name to Beaver-Tooth.
http://beaver-tooth.com/
