- Aug 17, 2014
It's gonna be OK. A new super steel will soon eclipse M390 and this will all be moot.
Bring on the Vanex Superclean!
I could not agree less. If your heat treat process is not able to hit the goals put forth, fix your heat treat process. If your airbags only deploy half the time they're supposed to, you figure out why and fix it. If that comes at a cost increase, so be it. It will not be a cost increase of "$500 to $800 for knives that used to cost $150 to $400".
It appears that some manufacturers are having issues, and are taking steps to fix it. I refuse to believe that EVERYONE is having "batch to batch heat treat issues due to required complexity". There is WAY too much soft steel out there for this to be an accident that slipped through QA. If it is, QA is terrible and needs to be addressed as well.
I say this as someone who's about to build some test mules, have them treated (and test confirmed) from 58HRC - 64HRC, for testers here to perform cut test and evaluations to put to bed any notions of what a proper heat treat is and what this steel is capable of.
/sigh
You seem to be misunderstanding my intent. If you look at the list of names thrown up on IG and YT of people pushing data to keep manufacturers accountable, you will see mine on it.
Explaining why it’s happening is not the same as being an apologist, or saying I don’t expect it to be fixed.
More controlled cut testing will definitely be the best way to continue garnering data. It would be really cool if the folks doing some of this work might put out some sort of agreed upon standards that everyone could use to conduct the testing. Might get really interesting if that happened. What do you think B Banter 247 @jcoolG19 ?
I asked Steel Will what hardness they use on their M390 Gekko on their Facebook page. You think I'll get a response.
Even if my Gekko is not as hard as it could be, it still holds an edge very well. At 30° included it holds up to scraping hickory at a 90° angle without rolling or chipping. It resharpens fairly easily.
How disappointed should I be? I'm trying to gain proper perspective.
More grist for the mill:
Just a random thought.
Regarding Lionsteel slip joints, isn't the blade tang annealed to match with the hardness of the spring?
So, if the tests were performed there, it may report lower numbers than that in the middle of the blade.
I already sold my Roundhead on. Till now I was still sure that I was doing something wrong. After all it was M390!There was more communication this morning. Lionsteel is taking the matter very seriously. Kurt should be going to Peters HT to verify the hit results, and one of the extremely low hrc samples has already been edge retention tested.
We’ll see how it shakes out from here.
