Here's a thread about how I came to these conclusions:
http://www.bladeforums.com/forums/showthread.php/1107561-New-burner-development-and-discovery
Heres a pic of various burners. I build and sell the burner in the second pic. It's a simple design, just put the
orifice about 1/4" away from the intake tube and it works. I use the term "orifice", as that's the important part of the "jet nozzle" as far as placement. You could buy a .045" drill bit cheaper than you can buy the mig tip.
Here's some info about your MIG tip size and expected BTU output:
Enter the Propane Gas orifice dia. in inches 0.045 inches
Enter the propane pressure in psi 20 psi
Orifice discharge coefficient 0.75 Coefficient Note: *
BTUs per Cu ft. 2498 BTUs / cu. ft.
Air to propane ratio for (1 cu ft of propane) 23.86 cu ft per min.(CFM)
BTUs per Lb of propane 21,591 BTUs / Lb.
Propane weight per gal. 4.24 Lbs / gal.
Burner Heat out put in BTUs 118,858 BTUs per hour
Air needed to support combustion 18.92 cu. ft. per min. (CFM)
Lbs. of propane per hour 5.50 Lbs./hr
Consumption rate in hours:
20 Pounds = 4.7 Gallons 3.63 Hours. (BBQ Size)
30 Pounds = 7.5 Gallons 5.45 Hours.
40 Pounds = 10.2 Gallons 7.27 Hours.
50 Pounds = 12 Gallons 9.08 Hours.
60 Pounds = 15 Gallons 10.90 Hours.
100 Pounds = 23.5 Gallons 18.17 Hours.
200 Pounds Other Cylinders 36.33 Hours.
