This is my first post though I have read much info here and thought I was knowledgeable enough to take apart and reassemble a RAT-1 knife.
Well, the first part (dis-assembly) went fine. It is the putting back together (properly) that has me bamboozled.
When I reassemble the knife with the 3 Teflon washers and two bronze washers I have the following two problems:
1. The closed blade wants to rub against the metal liner that is on the opposite side from the lock and not sit in the middle of is slot in its closed position.
2. Tightening and loosening the handle torx screws nearest the blade have an effect on the grips on how tight the blade is and whether it deploys easily or not, as does the pivot screws as they are supposed to do.
When I reassemble the knife I place 1 Teflon washer over the pivot pin on the liner lock side, then 1 bronze washer, then 1 Teflon washer then insert the blade on the pin. On the opposite side of the blade, away from the liner lock, I place 1 Teflon washer next to the blade on the pivot pin then the bronze washer then the metal liner.
After that I line all the holes up and attach the handles on both sides first, then the pivot pin screws.
I have tried moving the extra Teflon washer from one side to the other, tightening the pivot pin screws BEFORE putting on the handles and still no joy.
I am assuming that at least two of the Teflon washers go next to the blade, one on each side.
Thanks for your ideas and thoughts and any help you can give me.
Dave K
Dave K
