I've always thought in the back of my mind that a hollow grind could be a self jigging knife for sharpening. Though I have never tried it. Picture how a razor is like this.
In theory one can plunk the knife down flat on the stone with the spine riding on one side and the sharpening bevel riding on the other side and just run the knife on the stone until it is apexed. Now a razor gets more complicated (as I understand it I have never sharpened a razor) in that one only uses the stone so far on a razor and stops short of apexing or a bur in any case and then go to the strop for the final edge.
Anybody sharpen their robust hollow ground EDC this way or is this pure fantasy on my part ? ? ? ?
sIf you look up Chris Reeve videos, he does an excellent explanation of what is good about them, why he made his knives the way he did, and does....
I believe that convexing would help that issue. Then again, convexing is only further removing material from a relatively thin grind, which is obviously not going to hurt.I would be surprised if any real empirical study on this exists. The common test for edge retention is CARTA gel, which is too soft to cause the wedging issue and realistically only tests for edge retention at or near the cutting edge - which is to say, that hollow grinds actually have the advantage.
I have 3 Buck 110s. An old one from the seventies with a semi-hollow grind and rounded shoulders (more costly to produce). And I have 2 current models with a more traditional deep hollow grind and a very pronounced shoulder. One of these newer 110s, I put it to a course stone and I flattened off the the shoulders of the hollow grind.
It's almost immediately apparent when slicing up a few pounds of potatoes and rotating between the knives. The modern 110s make the initial cut much easier because they are thinner behind the edge (the old semi-hollow grind is actually thicker above the edge) but the old 110 and the modified new 110 slice all the way through the potatoes much more easily. There is considerably less drag.
Similarly, I had a Mora Companion HD that I convexed and it out battons my hollow grind Buck Reaper. Same thing. The should of the hollow grind binds up whereas the appleseed profile of the convexed Mora splits and goes through the wood faster. Again, side by side comparison of knives helps illuminate that.
NOTE: I'm not saying that you can't slice potatoes or split wood with hollow grinds. Obviously, you can.
I would like to see someone demonstrate that, given identical edge thickness, stock thickness, and bevel height, there exists a material that would be displaced easier with a flat ground blade than with the equivalent hollow ground one. In other words, show a material that would bind harder against the shoulder of a hollow grind than against the entire flat surface of the flat ground blade, which is thicker in all locations leading up to the shoulder. I have some doubts that such a cutting medium exists.
A full hollow is thinner at all points than a full flat, and a saber hollow of the same height is thinner than a saber flat at all points. I'm talking about equivalent grinds, not a full flat vs saber hollow. Otherwise the comparison would be apples to oranges. Your description of flattening out a hollow grind serves to compare two dissimilar grinds, not equivalent ones.Hey Marley,
I believe there are 2 issues. First, a hollow grind is thicker above the grind line compared to an otherwise comparable full flat grind. This can be seen by drawing the profiles on paper and demonstrated by placing a hollow grind flat on a stone and scrubbing down the shoulder to flatten it up to the spine. I've done it on numerous occasions and it takes some time and elbow grease. It's a process that removes a good amount of metal. As noted, I've done this with 2 Buck 110s with otherwise identical blades. The difference is very noticeable. Returning to a simple line drawing comparing a full flat grind and a hollow grind with similar spine thicknesses, when cutting difficult to separate mediums (potatoes, yams) the hollow grind is effectively a shorter wedge, thus creating a wider wedging angle.
The second issue I believe is the sharpness of the grind line. Again, using newer Buck 110 side by each with an older Buck 110 is telling. While both have the same height of the hollow grind, the newer knives have a very distinct and sharp shoulder while the older ones were made with a convexed transition. The drag on the sharp shoulder is definitely something I can feel when cutting potatoes, yams and squash. YMMV.
Hope this helps
It can be used for comparing to a flat grind with otherwise identical primary bevel height, stock width and thickness, and edge thickness. That's all I'm getting at.Visual bevel width should not be used as a comparison of geometry because it's a visual artifact of a given geometry being imposed on a given stock thickness. Stock thickness/width, specific geometry, and edge angle need to be held constant, but not visual bevel width. When dictating convex and concave geometries it can be difficult to make comparisons to flats since there's so many possible variations. Not all hollows or convexes follow a simple radius.
This is all I'm getting at.If you keep bevel height identical, it makes convex geometries thickest, flats in the middle, and hollows thinnest.
