- Sep 27, 1999
I was just out in the back yard wacking off
75 wacks with a large chopper 10" blade 1/4" thick carbon usmc bolo chopper.
75 wacks with a hatchet
75 wacks with a 1/4" cleaver
4" thick birch log
pros/cons
The hatchet was by far the most comfortable and cut in the deepest. a big plus for the hatchet is that is doesn't raise an eyebrow with anyone you meet.
my biggest problems with a hatchet are: not as versatile as a lg. chopper. plus the added awkwardness as a defensive weapon. I find for defensive effectiveness that follow cuts are difficult due to the weight ratio of head to handle. if you choke up on the handle to make it more controlled you lose alot of power. also holding the head and using it for fine work is uncomfortable.
The chopper allowed snap cuts that were accurate and more controlled. snap cuts are also very effective for brush and limb clearing. It very effective for defensive techniques. it can also be used as a draw knife, skinning, preparing food. It is extremely fluid for defense making my weapon of choice.
when cutting through a decent size piece of wood the vibrations were pretty uncomfortable. which made my hands sore. people definitely raise their eyebrows when they see it.
The cleaver was awkward and I would not recommend it for anything other than processing meat.
There were also uncomfortable vibrations with the cleaver when striking the wood.
so for backwoods I think I would lean towards the hatchet being that self defense isnt as much an issue and it will cover everything you need along with a multi-tool and small knife.
Though tasks were uncomfortable they were still do-able. So whatever the limitations of the tool at hand it will still do the job. Which in the end is an essential element of a survivalist making the best of a situation that is less than ideal.
4" thick birch log
pros/cons
