Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
True datThere must be hundreds of threads like this... I use Break Free CLP, Go-Juice, and mineral oil.
I've used them long ago. it's a silicone base I think. doesn't last too long. have to keep wiping. wax works okay and last a bit longer. I've used that too.....Anyone have luck with those Tuff Cloths?
Does Breakfree damage G10 if a little gets on the handle while cleaning the blade? Do you let your CLP soak in or protect with a wax afterwards?I forgot to say, just about any oil will prevent oxidation and rust.
But, many prefer to use a food safe mineral oil or similar. CLP or gun oil is good and I’ve used it for years to no harm. I usually wipe it down good if I’m going to do any food prep.
There’s tons of metal protection products and many are good but there’s some that has some chemicals that aren’t so good so look for the warning and use info on the labeling.
What do you use now? Is Ren wax best when applied alone or after a product like Breakfree is applied first?I've used them long ago. it's a silicone base I think. doesn't last too long. have to keep wiping. wax works okay and last a bit longer. I've used that too.....
never tried oil and then ren wax or any other wax. if your not gonna use for food prep I've used carnuba car wax and worked well enough. eventually wears off also form cutting tasks..... but in my experience has held up better than tuff cloth.What do you use now? Is Ren wax best when applied alone or after a product like Breakfree is applied first?
Sorry for the late reply, I’ve been recovering from a minor surgery. CLP shouldn’t affect g10 as it’s stabilized. Just wipe off the excess. Soaking really don’t help and the oil is fine enough to penetrate and a film is all that’s necessary. But it’s the use of cutting that will remove the oil or wax eventually. Just clean and reapply after use. Just keeping them clean and dry helps as much as oil or wax.Does Breakfree damage G10 if a little gets on the handle while cleaning the blade? Do you let your CLP soak in or protect with a wax afterwards?
it's not the end all, but gives some protection for a while.
I clean the blade well to remove oils, etc. Dry well with a paper towel or something. Then apply a thin coat of Renn, it will dry quickly, and then polish with a soft cloth (I use a clean cotton tee shirt). THEN take photos. The difference on Damascus blades is noticeable; they become lustrous.What do you use now? Is Ren wax best when applied alone or after a product like Breakfree is applied first?
