Pulaski True Temper, F.S.S. ....
backstory... (near Mexico border in Arizona)... I dropped
into a very busy blacksmiths shop in search of.... he
referred me to a local hole-in-the-wall tool smith. He
took me deep into the maze of the tool crib (darkness).
And, I picked this rusty, well used, Pulaski, buried in a bucket
of rust. (As you can see from the photo I gave $10.00 ( they
threw in a reasonable single bit 36" hickory handle for future
use ($5.)). To my best guess-timation it still had some
reasonable steel (under the rust). It appeared obvious that it
spent a great deal of time on the grinder.
I cleaned it up... the ax edges will need quite a bit of work. The
hoe/adze blade seems to have met a lot of rock. And, someone
must have used a hammer on the edges of the eye etc., some
mushrooming.
In creative mindset I'd like to think this Pulaski served on
the hotshot crews in one of our famous desert southwest
fires (i.e. Rodeo-Chideski). ... but, that is wishful thinking.
The single "H" on the opposite side of the TT /F.S.S.
matches that of previously shared member "MAINE"'s ax. Cool
to think we own steel from the same foundry (possibly shift/crew?
or at least some internal tracking mark).
I thought this was a great "semi-rare" piece of steel until I
interrogated the archives here and found one member had
a barrel drum full of "at least 50" of these. (Ha !) Oh well,
my goal (already ordered a octagon Pulaski House handle)
is to make this a permanent resident under the back seat
of my truck... perfect combo hoe/ax. Proud to have rescued
from the potential fate of disappearing in re-cycle.
...these ax edges will be a challenge. (thick and lumpy on one
edge, thin and chipped on the other....).
wt. 3.2 lbs.
Charles
https://imgur.com/a/1pR30
It looks OK but has a severely worn toe. Taking the rest of the bit back to match would be pretty extreme. I'd just file the bit to the Forest Service gauge and use it as is.
Thank you Square Peg... I thought (after I drew a line from heel to toe it seemed a
quite a bit of steel was lost (grinding ?). I will do as recommended (couldn't pass it
up...maybe should have...but for my needs will be fine). . Thanks
Charles
TT pulaskis are not as common as they once were. You did right to get it. Any factory marked FSS or GSA are good, but those TT are better!
I agree with S Square_peg comment to just sharpen it up, and use it as is.
A great choice for an in the truck tool :)
Thank you for the comments Muleman77... I agree on all counts.
Now...hesitant to show this as I am a pretender not a contender ! Ha ! I received the
octagon handle this afternoon so I thought I'd try to hang it ... It is tight , level, and
feels good in the hands. The photos are after 1 coat of linseed oil. Initially the handle
was very tight (wouldn't fit) in the eye...small incremental rasp work then 150 grain.
I think it turned out o.k. ... for a truck tool ! I tried to show all the angles most here
want to see. A nice handle for this piece of steel. Thanks
Now , to work the edges.
Charles
https://imgur.com/a/Nuvkz
You got a very good handle there. Not everyone is so lucky. Looks like a good hang. You're set now.
Thank You Square Peg... some minor edge work , a couple more coats
and will be placed in the truck ! Thanks again. Charles
btw ... I just filled out the comment card at House Handle Co. when I
placed the order and wrote exactly what I wanted. Very pleased with
what was delivered. Excellent transaction. Two day from Mo. to Az. .
Good to know I was one of the lucky ones ! I will do it again. I cannot
get this quality locally.
Thank you Muleman77 ...my main goal was just to not screw it up. Tomorrow I'll test
run the hoe in our local soil...caliche ! 3 words to describe it... impermeable, calcium
carbonate ! Should be a good test of the steel and the hang. Thanks again... Charles
Discretion is the better part...
Upon advisement from members here I attempted to gently re-edge the
ax / adze... using what the condition upon arrival presented. (had heavy
grinder work in it's lifetime). I declined further grinding...just used a metal
file (many strokes to get to this point... a multitude of divots required
correcting). I will hone as I go. I know, not a wall hanging Da Vinci... but,
now a functional truck Pulaski. Looking forward to the field test. It sleeps in
the truck.
(btw.... this quality steel had the very melodious "bell ring" tone when
struck with the file base. Very cool. :))
Charles
https://imgur.com/a/LzBHc
the truck.
Charles
Drum4fun's pic:
Nice work on that grind - I like your handle :thumbsup:
Agent H thank you . I was afraid I would do too much so thought it prudent to stop
(probably before I needed too ! ) . But , for my use I think this will be a very nice
"rescue" tool. Reassuring to know it is on board. My edge needs work but to quote
a mentor..."the enemy of good...is better".
I think your handle is spectacular... a lot more visually appealing then mine. I haven't
swung mine much, but the octagon handle sure feels nice in grip (with gloves). Your Pulaski
looks work ready . Thank you for sharing the photo.
Charles
Thanks Square Peg...and, thanks for the input on "how much is enough" guidance.
Proud to put this one back to work !
Charles
mushrooming.
wt. 3.2 lbs.
Charles
I have one of these pulaskis as well. Where did you find the information about the H stamp?
Bumping an old thread. Just picked up a True Temper FSS double bit that also has the “H” stamp. Any axeperts willing to share info on the stamp and dating TTS heads? Thanks!
The best method of dating is by the presence or absence of eye ridges.
As for the 'H', if it's small and deep it's likely a factory lot symbol. If it's larger or shallow then likely denoted ownership to a specific group.
I think these are some of the nicest pulaskis if they're in good condition. They tend to get very worn down.
Thank you both. It has what appears to be the original handle in it. Will take a closer look for ridges, but doubt I’ll see anything.
FWIW, I thought I read somewhere the FSS was established in 1949.
