If you go to the big river site, you can do a search for something called a "leaf antenna." They might also be called "amplified HD Digital TV Antenna." Generally, those can be plugged into the "antenna" connection on your TV. A lot of the antennas are about the size of a sheet of paper and can be stuck on a wall or positioned near a window. You can go to a site like this:
https://www.fcc.gov/media/engineering/dtvmaps
and you will see the strength of the signal you get in your area. If it's decent, you should be okay with a simpler antenna. If the signal is weak, you can get a slightly upgraded antenna. A setup like this will usually give you your local channels for free. Those are usually about the same channels that you get through basic cable. You could go through the channels using your remote like "the good ol' days" that way.
Roku, Chromecast, Apple TV, and other "stick" type devices should let you access Netflix, YouTube, and other services. I've only ever used Roku. That's pretty easy to use and Roku offers a lot of different channels and services built in. These channels look like the icons on a smartphone.
For YouTube or Netflix, if you find searching for the things you want with a remote tedious, I believe you can also get universal TV remotes that have small keyboards built in. I have one of those on an older Vizio TV and it makes searching for things pretty easy.
I would definitely cancel the cable as long as you have good internet. If you didn't want to spend too much time figuring things out on your existing TV, you could even consider getting a TV with Roku built in. I just got a 55 inch TV with Roku, Netflix, etc built in for $200 and it connects wirelessly well enough to stream in HD. You could recoup those costs relatively quickly if you cancelled cable service.
Overall, the amount of stuff out there for free or lower cost than cable keeps me more than entertained. There might be a bit of an adjustment period, but the savings would make it worth it.
