I'm the opposite, but then again I'm not that fond of a scandi grind either.
The puukko's I've had have more of a convex, high saber type of grind than a true scandi. The couple scandi's I've had were acceptable at cutting but only excelled at hard surfaces like wood. The cheeks created a lot of discontent for me for other uses. Puukko's that tend to have more of the rhomboid blade shape do not have the problem. Maybe it was the moras and custom I had that was designed with the bevel that created more pinching than I liked. I'm really a fan of high savers for most cutting anymore, but the grind certainly isn't the only aspect of a knife to consider.
Slipping off the front of a puukko could be a concern if you get excited and careless. Use pull cuts and the worse that happens is you drop your knife. Contoured handles would mitigate that some too. Guards make it safer what I tend to prefer for such a situation. I've probably slipped more with fillet knives than hunting knives though, and I've not seen a guard on a fillet knife. Cutting gloves can be your friend if you have the option.
I'm not sure why you wouldn't want a point knife. Thinking of a very common hunting design, the buck fixed blades with clip points, are all very pointy and highly regarded for cleaning game. Maybe, we've worked in different fame as I've not had to clean anything larger than a white tail where taking skins off can pretty much be done with brute force.
