- Feb 1, 2001
I bought a Paragon SC2 and used it for the first time to heat my steel(1084). After letting the Paragon warm up for 30 minutes, I Normalized at 1600F for 10 minutes, let air cooled. Then did thermal cycling at 1550, 1500 and 1450 for about 5-6 minutes each and air cooling between each cycle. Then I put it back in to the Paragon that was at 1500 and let the knife sit for 15 minutes(5 to fully heat and 10 to soak). I quickly opened the door and dunked the knife for 15+seconds into my 130f canola oil quench tank of 5 gallons and moved around spine to edge. The blade was a nice cherry red when it when in but is still soft as butter! A file grabs easily! I tried a 2nd time(not the full normalizing and thermal cycling) heating to 1500f and quenching with no success.
Any ideas what might have happened? I have made 3 knives total before this and used a gas forge to heat to non-magnetic and quenched and the steel hardened right up! I bought this Paragon so I could have very accurate temperatures but it appears something is not right. I have pictures and a short 45 second video I could send to anyone wanting to see what I did. I just can't post it here as I'm not sure how to. Email me at codamonster@gmail.com and I'll send you a video showing the shade of red hot steel coming out of the Paragon. Thanks for any help!
