Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
I saw where a maker was cutting against the grain on his which was reducing warping. Makes me curious!We haven't tested AEB-L in the transverse direction, but every other steel tested shows at least some difference between orientation. Even high toughness steels like Z-Tuff.
What got me started was someone more experienced than me telling me I was about to cut my blades the wrong direction, an evening of debate later and I learn that aks steel is all cross rolled besides the niagara steel, sooo maybe smarty pants just need to keep their mouths shut or ask where ppl got the steel before opening up a rabbit hole?!For custom knifemakers that argue over 5 minutes of austenitizing time, or that not using cryo makes a knife bad, etc., saying that grain direction doesn’t matter is ridiculous. Make the knife correctly. Don’t handicap it.
The steel is not 50:50 cross-rolled. It has an orientation to it and the difference in toughness can be up to 50%. Even in high toughness, “cross rolled” PM steels.
So for every 12 x 24 piece of aeb-l I get I need to etch and get a microscope bc the supplier says its cross rolled and has no grain direction?The steel is not 50:50 cross-rolled. It has an orientation to it and the difference in toughness can be up to 50%. Even in high toughness, “cross rolled” PM steels.
We cross roll (Typically rotated 90 degrees 2 to 3 times during the rolling process) titanium and aerospace alloys all of the time to meet tensile and bend test requirements. We could do the same for CPM if we knew it made a measurable difference. The CPM billets we buy from Crucible are 11 to 14" wide and 4 to 5 " thick when they start out and we roll them in multiple directions to get them out to 26 to 28 inches wide. It's kind of like rolling dough, except it's really hot, a lot harder and our rolling pins are 24 inches in diameter and weigh 6 tons each.Once they get to .500" thick we stop rolling, anneal the plate, shotblast to clean the surface and then finish roll in one direction to get the length and thickness. The final roll direction for CPM is along the 36 " dimension. I can assure you, our steel gets rolled in more directions than just about anyone else in the world.
Bob Shabala
President
Niagara Specialty Metals
Also, were just chatting about the science to it, that shouldn't be an issue with anyone!
Not sure where you’re getting your information from, but everything rolled at Niagara Specialty Metals @nsm is cross-rolled.
And yes, you should be paying attention to the direction your sheet was rolled in.
Nothing has changed. Alpha Knife Supply was obviously mistaken.
Last time I bought a piece of steel (IT WASN’T FROM AKS!!!) the seller also told me “it’s cross rolled”, but Haakonsen once told me there’s a final direction in which the steel is rolled, we can’t roll the steel in every direction forever! So now I take stock removal blades with a bit of caution, because if even the steel supplier doesn’t know the rolling direction of the steel...The steel is not 50:50 cross-rolled. It has an orientation to it and the difference in toughness can be up to 50%. Even in high toughness, “cross rolled” PM steels.
This is my first piece of steel wider than 2 or 2.5 inches, so Ive not ran in to this problem to solve yet.
Do you etch a corner and try to do a macro picture of the grain?
I dont have any visible rolling marks, no rounded edges, all four sides were cut. There is some stripes painted on the back would the direction of that be a clue
