Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
If you want to use loctite use Loctite 222(purple). I use blue or purple loctite 90% of the time. You don't have to use one though.
You don't have to use it but the pivot will loosen up if you don't use something. The other option is teflon tape, I have used both as well as nothing and my Umnumzaan didn't burst into flames or make insinuating phone calls to CRK behind my back or anything so I'm sure you'll be fine.:thumbup:
I used mine for a few months without loctite, and it didn't loosen up. CRK uses nice thin threads with a high threads/inch count and short lead compared to other companies, so it doesn't back out the first opening like, for instance, a Benchmade without loctite does. YMMV
Just use teflon tape. You don't need to wait for it to dry and you can get a roll of it that will last a lifetime for like $2
CRK recommends the purple Loctite which is hard to find (I have only found it at Brownells)
You got that right. I've been trying to find it locally to save on shipping. I should have just ordered it online sine I've already spent more on gas! I got a takedown kit from CRK and I got a tiny bottle, I'm just not sure how long that will last ( I plan on using it on my other knives also).
As long as it doesn't cure in the tube/"bottle" after you open it, if you use it correctly, that little tube is somewhere between a five year and lifetime supply.![]()
That is correct, the tolerances on the Sebenza are such that the design allows for the screws to bottom out and that's how it works.
Just to clarify: The pivot screw does not bottom out, the bushing just allows you to torque the screw sufficiently to prevent it from backing out under normal use. The tolerances of the bushing and washer system establish the freedom of movement for the blade, the pivot screw and cap simply secures this assembly.
