I'm going on a long term off the grid thing in the desert and am trying to use mylar as a ghetto form of insulation. I'd love to do more but money, time and bulk don't allow it. I know enough about conductive insulation but have never done much with radiant. My questions are as follows-
1) I want to put some mylar on top of my cooler to keep the sun from beating on it but since its so fragile I would put a layer of duct tape or something over it. Mylar works the same if covered, right? I assume it does because it's blocking rays that are outside of the visible spectrum but I don't know if covering the reflective surface will hinder it. This would also work inside the cooler to retain cold, right? I know insulation works for cold or warm but I'm not sure if radiant does this
2) I'm thinking of layering some mylar around my tent to keep the morning sun from turning it into an oven and keeping the cool air in (I built a swamp cooler from a bucket). Since its so fragile though I'm going to sandwich it in painters plastic. Plastic won't inhibit the mylar, right? See question 1-
3) and third, mylar under the tent? I know this would help when it's cold but during the summer I've always dug a few inches into the ground to stay cooler. Would contact with the ground here help or hurt. And wouldn't mylar reflect my heat back into the tent? Or is that negligible. I'm on the fence about this one.
I appreciate any help on this. I know that direct contact with mylar will make it a conductor which isn't what I want so I'm unsure of these things.
