Hello all,
Long ago I put together a belt grinder. Direct drive, single phase, fixed speed (33m/sec belt speed if I am not mistaken). Works great even though a few things could be totally improved (may do it in a near future).
The thing is that I have a spare 3kw three-phase motor and I was thinking about putting it in my belt grinder along with a VDF. It could be almost a bolt-in replacement (it will fit with little to no modifications).
The VDF needs to be single phase input - three phase output and suitable for 3kW. I do have a 3phase service (380v) but I would like it to have single phase input, just in case I move it to another location with no 3ph. I only need the speed control feature, I don't need any more bells and wisthles but anyway I guess a VDF like this is not going to be cheap.
So, after all this babling... the question is: What benefits do I get from a variable speed grinder? What speeds are used with which type of belts and for which materials?
Besides knife making, I use it also for general fabrication (hobby stuff, I don't make a living on that).
I use my belt grinder mostly for mild steel, some stainless, some aluminum, the ocasional wood (I also make wooden spearguns and sometimes shape the stock with the grinder), home made micarta and stuff like that. I have noticed that with wood I sometimes get burn marks and I think that running the belt at lower speeds may result in a better finish. What about polishing?
Other than that, is it really worth the trouble or should I stick to my current setup?
Thanks!
Thanks!
