- Jan 26, 2012
But not the question of the op. Cold steel serrations are inferior to spyderco for actual use. One time sd use is different.The lock is an integral part of the functionality of any locking folder .
Ironically the only SE knife I know of with a warranty voided for non-SD use is the Spyderco Civilian . I believe the Civilian SE is ground more acutely than their normal and the hook tip looks kinda fragile too . I know people do use their CS SE's for their regular chore knives with no special complaints . I just think they are a PITA to sharpen and I like my SD knives to be factory sharp . Also , the CS Black Talon 2 is the much superior alternative to the Civilian . Stronger lock , better steel , and stronger thicker hook and far less expensive . And no special warranty restrictions on normal utility usage .But not the question of the op. Cold steel serrations are inferior to spyderco for actual use. One time sd use is different.
With the civilian a stronger lock is irrelevant. Which side of the blade are you considering using? I'd use the sharp side if need be.Ironically the only SE knife I know of with a warranty voided for non-SD use is the Spyderco Civilian . I believe the Civilian SE is ground more acutely than their normal and the hook tip looks kinda fragile too . I know people do use their CS SE's for their regular chore knives with no special complaints . I just think they are a PITA to sharpen and I like my SD knives to be factory sharp . Also , the CS Black Talon 2 is the much superior alternative to the Civilian . Stronger lock , better steel , and stronger thicker hook and far less expensive . And no special warranty restrictions on normal utility usage .
In a fighting knife , lock strength is ALWAYS relevant in my view (but "why" is beyond the scope of this thread and better for Prac-Tac forum) . YMMV .With the civilian a stronger lock is irrelevant. Which side of the blade are you considering using? I'd use the sharp side if need be.
Respectable members here report cold steel serrations fail in edc use. Spydercos don't. That is the point of this thread. If your concern is an edc that can be pressed into edc, the choice is clear.
The knife you mentioned is far more expensive than a Pacific salt. I'd go spyderco all day. Then again, I do carry and use it for more than just sd.
So post that topic there. This is the topic here. Spyderco serrations are better. The other things you mention are not the topic.In a fighting knife , lock strength is ALWAYS relevant in my view (but "why" is beyond the scope of this thread and better for Prac-Tac forum) . YMMV .
Only better in specific ways , NOT in every way . Not everyone needs the same type of performance .So post that topic there. This is the topic here. Spyderco serrations are better. The other things you mention are not the topic.
Cold Steal’s serrations remind me of those found on a cheap steak knife. You need that special croc stick to sharpen them at home.
Good luck with that because that means you are working with one grit.
They are better in a more general way. Ie, for most uses rather than specific uses.Only better in specific ways , NOT in every way . Not everyone needs the same type of performance .
The factory fresh or equivalently sharp CS SE provide superior cutting with less force applied and less tendency to grab or catch . Just harder to sharpen back to that same standard (because of the finer small teeth ).
It would be nice to see some actual testing proof of the durability of the CS SE in CTS-XHP vs Spyderco SE . Most peoples practical experience with CS SE is from the old AUS8 , much less tough !
I just bought the ACCSHARP Diamond rod sharpener, it has both a round and straight tapered sharpener rod.
It is a really great tool cost $10.98 at Amazon.com.
https://accusharp.com/product/030/
Removed it thanks for informing me.Are you sure these accusharp guys are affiliated with bladeforums? If not then plz remove the link.
