WaltE99
Fickle Bastard Blades
- Oct 5, 2015
Hey guys, I'm relatively new and need to know how everyone determines if their wood is dry enough to use or stabilize. I was just looking at a knife I finished up maybe a month ago and noticed the handle appears to have shrunk enough to feel the sharp edge of the tang. Instead of purchasing scales, I bought some wood from a woodworking store that was said to be kiln dried. About a foot each of 8/4 Bubinga and Padauk. So obviouly I should have dried the wood a bit more.
Question 1: How do you determine if the wood is dry enough to use or go to stabilization? I did a search and found a thread in which moisture meters were being discussed and I think Stacy said that they are pretty accurate in the middle of their ranges but not so much at the extremes. Since they typically range from about 5% to in the 40's and we should be looking for around 6% - 7%, it seems to me that moisture meters would not be accurate enough. Maybe Stacy was only talking about the lower priced ones, but if I'm going to plunk down a $100 - $125 for a mid-priced meter, I want to know it's going to be useful.
Question 2: Would using a food dehydrator be a good way to further dry out some scales or blocks?
Thanks!
Thanks!
