- Apr 6, 2017
I actually had the opposite problem. Those hourglass shaped standoffs used by ZT on the 0620 are alumnum I believe and highly prone to stripping. I actually had one on my 0620 that would get somehow stuck so the screw didn’t want to feed in or out of it. Don’t get me wrong the 0620 is a great knife and I love it, I just find it abit heavy.
On the other hand I am not saying the Emersons ar perfect either. The older backspacer versions I prefer have the screws fastening directly into the Ti which is also not good.
If your knife was creaking when you put pressure on the spine that was likely a bad lock. The creaking was likely abit of lock slip. In that case you should send it to Emerson for warranty work.
Sorry you had a bad experience with them.
I'm not sure if they are aluminum or not. They haven't given me issues with the threads, and I've taken mine apart a fair number of times, but ZT does use aluminum for standoffs on other knives. It does appear to be oxide coated steel to me, but I could be wrong.
Yeah, see, I thought the issue was the lock too, but the lock wasn't slipping. I checked very thoroughly. In fact, the lock was really sticky. The creak seemed to come from the scales and/or pivot assembly, which was also tight as is feasible to adjust it.
