- Jan 24, 2001
Hey Y'all,
Today I was messing around and I've been wanting to do some stainless blades for guys that I know who hunt a lot. I decided to see if I could forge a blade out of it and was successfully able to do so without it cracking anywhere.
Then I started looking at all the old posts dealing with HT'ing 440-C and decided it was worth experimenting with a torch hardening and edge quench in mineral oil just like I do for my carbon steel knives. I torch HT'ed the blade until it was fairly hot cause I read that the hardening temp is fairly high for 440 (I also read somewhere that the magnet test does not work for 440) then I edge quenched it in mineral oil that was 150F. The blade got super hard but also seemed to harden further up the blade than I'm used to cause the back of the blade seems fairly hard too , though not quite as hard as the edge, but it was a rather small blade (1/8 x 1/2 x 3 inches). I had the oil about half way up the blade on the quench. Also I'm using a gas forge if that makes a difference.
Now for the questions:
1. Is this a viable way to HT 440-C or am I doing something fundamentally wrong here that I just don't know about?
2.Does the magnet test work with this steel or not?
3.Did I just have beginners luck with eyeballing the hardening temp? I didn't use any soak times or anything like that, did it just like my carbon steel blades except for the magnet.
4. If I get a good hard edge and a softer back on another blade does anyone know if it will show any sort of faint temper line? Should I use a slower or faster quench? I don't imagine that you can etch stainless too well, but if you can let me know that too.
5. does a multiple quench or repeated thermal cycles refine grain structure or help the alloying elements make better carbides like 5160 or 52100 in 440-C?
6. Should I start at the low end of the tempering cycle (350F) or does someone have a better place to start for a knife blade temper? Do multiple tempers benifit this steel?
Thanks for any help and advice anyone can give me on this subject, I really appreciate it.
HillbillyChuck aka Chuck Fogarty
