- Mar 1, 2011
Posting this up here because this sub-forum seems to do the most acid-etching. . .
. . .will the PCB etchant from RadioShack etch thru the mill scale on steel or does the scale need to be removed so there isn't an oxide layer blocking the ferric choloride?
I'm not etching a knife. . .I'm etching some mild steel plate for some decorative work I'm doing; this is the first time I've tried the acid-etch so I'm trying out on a small 3" square piece of scrap first. I'm also trying out something I've seen done on car paint jobs as well. . .I sprinkled water on the steel before I spray painted and let the water bead up, then I spray painted the metal with the water droplets on it so the paint won't adhere to the steel where the water droplets are. . .after the paint dries wipe of the paint that didn't adhere and allow the acid to etch in a random pattern to created an aged look to the metal.
Thanks for the help!
