When you have a knife that has a very loose action what do you think is the solution?
Would new washers be enough to tighten this up some?
I sent the knife to CRK and had the washers replaced and asked for a more stiff action. When the knife came back the action was just the same. Blade will swing closed and hit your thumb if you let it. I measured the old washers and the extra set I had fitted and they are exactly the same. So just curious, was I wrong in thinking the washers would resolve this problem?
I have reached back out to CRK and they said this would require sanding of the pivot bushing.
Would this concern anyone? I know CRK knows there product and if they say so I have no problem with it. However wouldn't sanding down the pivot bushing also make the clearance between the handles change as well? Would this really be needed?
Has anyone had any experience with this? I am having a hard understanding how all this works.
Thanks in advance,
Thanks in advance,
