- Feb 15, 2014
Reate Knives -------- Wave (Designer : Solo Jack )
Manual open, ball-bearing system 3-D machined Titanium handle.
Specification
Blade Thickness:0.157"
Blade Material: Bohler M390
Blade Edge: 3.15"
Hardness:60-62
Overall Length:7.625"
Handle Material:6AL4V Titanium
Screw Material:6AL4V
Handle Insert:6AL4V
Weight:3.76oz
Finish:Stonewash(anodized)
Locking:Frame Lock
Features:
Full-flat ground M390 steel blade
Full titanium handle construction
Checkered titanium inlay grips
Ball-bearing pivot
Milled titanium pocket clip with "ball-bearing" milled contact point
Three notches on flipper optimize finger contact for consistent engagement
Reate Knives would like to talk a little bit about one important techniqueFreeze Edging Skill.As the final process for a blade, edging has a great effect on the performance of the knives, after all, the edge part is the main function area when using a knife. Normally, edging is operated on a high-speed running grinding wheel or grinding belt, which produces a very high temperature. Without a cooling system, the temperature on the edge goes up instantly to hundreds of centigrade, when it gets worse, it will burn and leave heat marks on the blade. Tempering or even annealing will happen on area of the edge where the temperature increasing instantly. It will harm the hardness and durability of the blade. Thats why some knives passing the hardness standard test but still easily get worn in actual use.Reate Knives are using the freeze edging technique. During grinding, the temperature on the edge is controlled in a certain level of degree, which helps keep the hardness after the heat treating. Therefore, the sharpness and durability of the blade are assured. This helps bring the performance of the material to the best.
Thanks for your time.
Specification
Blade Edge: 3.15"
Hardness:60-62
Handle Insert:6AL4V
Weight:3.76oz
Locking:Frame Lock
Features:
Ball-bearing pivot
