Reate Knives 2017 high-end knife: K-2
EN
  • Poll choice...
    Votes: 1 100.0%
  • Poll choice...
    Votes: 0 0.0%
  • Total voters
    1
We would like to share the details about K-2 here with you.
Ceramic ball bearing system
3-D machined Titanium handle
Blade Length:3.9"
Blade Thickness:0.157"
Overall Length:8.8"
Hardness:60-61HRC
Blade Material:CPM-S35VN
Handle Material:6AL4V Titanium
Weight:4.9 oz
Locking:Frame Lock
Balde finish:Satin finish
Handle finish:Blue/Bronze/Engraved bronze/Engraved silver/Black PVD coating
Here are some photos of K-2.
Reate Knives would like to talk a little bit about one important technique—Freeze Edging Skill.
As the final process for a blade, edging has a great effect on the performance of the knives, after all, the edge part is the main function area when using a knife. Normally, edging is operated on a high-speed running grinding wheel or grinding belt, which produces a very high temperature. Without a cooling system, the temperature on the edge goes up instantly to hundreds of centigrade, when it gets worse, it will burn and leave heat marks on the blade. Tempering or even annealing will happen on area of the edge where the temperature increasing instantly. It will harm the hardness and durability of the blade. That’s why some knives passing the hardness standard test but still easily get worn in actual use.
Reate Knives are using the freeze edging technique. During grinding, the temperature on the edge is controlled in a certain level of degree, which helps keep the hardness after the heat treating. Therefore, the sharpness and durability of the blade are assured. This helps bring the performance of the material to the best.
Thank you very much for your time.
Reate Knives Team.
