- Feb 15, 2014
We are glad to inform everyone about this knives(Iron) which is our in house design will be released in this week. They would be available at our dealers in next week.
Specification:
Bearings:Ceramic ball bearings
Open Length:7.87”
Blade length: 3.25”
Closed length: 4.29”
Blade thickness: 0.157”
Blade material: Bohler M390
Blade material hardness: 61HRC
Handle material: 6AL4V Titanium
Weight: 139g/4.9oz
Blade finish: Satin finish
Handel finish: Grey(Bead blast)
We have 2 versions for Iron---Flipper and Thumbstuds
Each version has different colors below:
1. Flipper Bead blast screws with Brown micarta inlay M390 blade satin finish
2. Flipper Bead blast screws with Green micarta inlay M390 blade satin finish
3. Flipper Bead blast screws with Carbon fiber inlay M390 blade satin finish
4. Flipper Purple screws with Brown micarta inlay M390 blade satin finish
5. Flipper Blue screws with Green micarta inlay M390 blade satin finish
6. Flipper Green screws with Carbon fiber inlay M390 blade satin finish
Flipper version back side:
7. Thumbstuds Bead blast screws with Brown micarta inlay M390 blade satin finish
8. Thumbstuds Bead blast screws with Green micarta inlay M390 blade satin finish
9. Thumbstuds Bead blast screws with Carbon fiber inlay M390 blade satin finish
10. Thumbstuds Purple screws with Brown micarta inlay M390 blade satin finish
11. Thumbstuds Blue screws with Green micarta inlay M390 blade satin finish
12. Thumbstuds Green screws with Carbon fiber inlay M390 blade satin finish
Reate Knives would like to talk a little bit about one important techniqueFreeze Edging Skill.
As the final process for a blade, edging has a great effect on the performance of the knives, after all, the edge part is the main function area when using a knife. Normally, edging is operated on a high-speed running grinding wheel or grinding belt, which produces a very high temperature. Without a cooling system, the temperature on the edge goes up instantly to hundreds of centigrade, when it gets worse, it will burn and leave heat marks on the blade. Tempering or even annealing will happen on area of the edge where the temperature increasing instantly. It will harm the hardness and durability of the blade. Thats why some knives passing the hardness standard test but still easily get worn in actual use.
Reate Knives are using the freeze edging technique. During grinding, the temperature on the edge is controlled in a certain level of degree, which helps keep the hardness after the heat treating. Therefore, the sharpness and durability of the blade are assured. This helps bring the performance of the material to the best.
Thank you very much for your time.
Reate Knives Team.
[/URL][/IMG]
Specification:
Open Length:7.87”
Blade length: 3.25”
Weight: 139g/4.9oz
Reate Knives Team.
