What does the group generally recommend for pivot lube/blade oil?
I’ve got a bug out that is just about perfect in terms of its action. It flicks open easily. It drops shut completely. And there’s no blade play. I’m hesitant to take that apart or change much with it right now.
I also have an Adamus, and I know that that steel is somewhat corrosive. So I’m interested in knowing if there is a pivot loop that can also be used to help reduce the risk of corrosion on that knife.
Let me know if you have a recommended product that you’ve had good results with in the past.
