- Sep 21, 2023
I am in the process of gathering the parts to build The Redbeard Ops Press, I live in Australia
1. I have a DC Motor Single Phase 5HP Asynchronous Electric Induction Motor 3450RPM AC Current Rigid Mounting ODP for Air Compressor Strong Load Capacity
2. Yaegoo 11GPM 2Stage Hydraulic Log Splitter Pump, 3000PSI
3. VEVOR Hydraulic Oil Tank Fuel 10Gal Hydraulic Reservoir Steel w/ Filter & Gauge
I am unable to find 1 Spool 20 GPM Prince RD-2575-T4-ESA1 DA Valve at a realistic price under ($400.00
I can get both of the ones listed below for under ($100.00
1-Spool Hydraulic Directional Control Valve P40 SAE Ports Double Acting NEW AU
or a
1-spool Hydraulic Directional Control Valve 3600PSI P40 SAE Port Double Acting
and a 2" Bore x 8" Stroke Heavy Duty High-Pressure Hydraulic Cylinder rated 3000psi
I do not know which one would be the best for the press
any advice would be gratefully appreciated
and thanks to Readbeard ops for his very good help to me
or a
