- Dec 27, 2013
Hello all,
A little while back I was lucky enough to get ahold of a few pieces of a cashed SR-71 Blackbird, some of which was turned into knife blades.
Here is another knife made from the aircraft's wreckage, in completed form, Mecha style.
Golden color is from the modified heat treatment, used for over-alloyed titanium. This knife is not very hard, sort of a space-age bronze knife. Incredibly heat-resistant material.
Chisel grind, flat on one side and slightly diamond-section on the other.
Spine has a diamond shape on the distal end, reminiscent of high-performance aircraft.
Snug leather sheath to protect the blade.
The bolt handle ornament is also from the SR-71 pieces. Each threaded fastener has a serial number, along with many other small pieces of the meticulously-made aircraft. The lanyard hole is a rivet hole.
Below are a few photos of the piece being shaped into the knife billet before refinement.
It's a real pleasure to make use of such an amazing piece of aerospace history, no pun intended.
