Hey guys,
I've used the Lansky Deluxe 5-Stone System to sharpen several knives. (https://www.lansky.com/deluxe-5-stone-system.html)
Am happy with it, but each stone has gotten gunked up with a mixture of metal shavings and sharpening oil.
Wasn't aware I'm only supposed to use the oil for cleaning. Had been keeping them oiled while sharpening with these standard Alumina Oxide stones.
I bought the Lansky Eraser Block for cleaning, I think that only made it worse.
I've now started to clean them with hot water and a toothbrush. That didn't work too well, the shavings/oil/eraser mixture is kinda stuck in the pores.
I've progressed to using sandpaper on a flat surface. That works, as expected.
I can continue using sandpaper until I've taken off enough material to hit "virgin ground" on each stone.
Here are my questions:
A) If I continue with sandpaper, I'll be going through quite a bit of it. Would you recommend I just get myself a diamond file?
If I get a file: would you treat each of the stones with the same file? The stones have different grits (Extra Coarse is 70 / 120 / 280 / 600 / Ultra Fine is 1,000).
I might be overthinking this, but I'm wondering if I need to use files that match the grit of each stone.
Using a 300 grit diamond file on the 1000-grit Ultra Fine ceramic stone doesn't make sense to me, for example. Just a gut feeling.
B) Do you clean your Lansky stones after each sharpening? If yes: just using the Lansky Honing Oil and a paper towel? Is that enough to keep the pores clean?
If you'd recommend I use a different method to clean the stones now, please let me know. I'm all ears.
Thanks in advance, hope things are good in your neck of the woods.
Greetings from Germany
