- Jan 8, 2005
Hey guys, I am wanting to take up reloading as a hobby and have used some borrowed equipment but don't own any of my own right now. From the research I've done thus far I've narrowed it down to either the RCBS Rockchucker Supreme Kit, the Hornady Lock-n-Load Classic or maybe a Lyman T-mag 2. Any thoughts or comments on any of these from people that have used them would be appreciated.
A big question that i have as I've only done a little reloading thus far is that if you use dies that have locks on the rings do you have to keep adjusting them every single time you have to screw in the die or not? If you can truly set a lock-ring and just screw in and out to that point I'd prefer either the Rockchucker or T-mag, but if every single time it is going to require a lot of tinkering/readjusting I'm going with the Hornady Lock-n-Load. My first hand-experience thus far has been limited to using others turret presses that had different heads for each caliber. If I go T-mag I want to just be able to screw the dies in and out and not have to mess with buying/changing turrets, if I want to change turrets I'll get a Lee Classic Turret. My personal preference is kinda 50/50 between the Rockchucker and Lyman, assuming lock rings really work, if not then I'd be between the Hornady and Lee Classic Turret.
Oh and I'd be looking to do both pistol and rifle (no magnums or precision), prob 80% or more pistol. I've done some batch and some semi-progressive, all I've used to this point are turrets with the dies already set.
Thanks for the help.
