- Apr 20, 2001
A few days ago I stopped into my local “Feed & Seed” store and saw that they had put out a large selection of the Remington Sportsman Series of knives, they had about a dozen slip joint patterns, 2 lock backs and 4 fixed blade models. All the slipjoints were just $9.99 and I saw this Stockman on impulse decided to buy it to check them out.
Here are the stats from the front and back of the blister pack:
Black Delrin Stag handles.
440 Stainless Steel Blades. (I’d bet money it’s 440A)
Clip, Spey and Sheepsfoot Blades.
4 ¼” Closed
Made in China.
First off, 1 complaint, someone in China or at Remington needs to learn to measure, both the front and back of the package say “4 ¼” closed”…the knife is only 4’ closed, not a huge difference, except I collect Cattle King/Jumbo Stockmen and was a little irritated at the mistake.
Overall fit is pretty much perfect, no gaps or misaligned parts, no visible flaws in the metal or Delrin parts. When I first took it out of the package in my car, I found the walk and talk to be a little sluggish and weak. The edges were all sharp but very “toothy”, similar to what you find on a new Case knife these days in stainless steel, like they were sharpened on an electric sharpener.
After I got home, I oiled the pivots and let it set for a while, when I returned and started opening the blades, I found black buffing compound oozing out with the oil from all the pivots and from between the backsprings and liners. (brass liners), the more I worked the blades, the more crud came out, but the better the walk and talk was. After getting all of it flushed out, the knife now “snaps” really well, I guess the crud was causing the sluggishness.
I touched up all three blades with a DMT “fine” diamond hone, and just a little time brought them all to hair popping sharp!
I took it out today and did some whittling for about 30 minutes giving each blade roughly equal time and afterwards the blades would still shave, that’s not a hardcore test, but for a $10.00 working pocketknife, it held it’s edges well.
I was surprised, this turned out to be a decent knife once I cleaned the pivots out and touched up the edges. It’s comparable to the Steel Warrior or Rough Rider knives.
4 ¼” Closed
Made in China.
