Price is $300 ea, one per household please.
Did you try a cape cod cloth or a buffing wheel with rouge?
Sent from my SAMSUNG-SM-G925A using Tapatalk
Does anyone have any suggestions on how to remove light scratches on a polished blade. Was going to try Flitz today but couldn't find the tube I had. I did try Brasso but no joy there. Any suggestions appreciated.
I sometimes feel like I'm repeating myself. But some of this advice probably should be repeated so that more people can hear/read it.
Removing scratches requires using an abrasive with a coarse enough grit to match the scratch. Then you work from the "scratched grit" up to the desired level of polish. I've found that most blades really don't have much of a polish on the body at all. Most seem to stop somewhere between 220 and 320.
The idea of using a powered system with a very high grit abrasive can work. But it's going to leave a polish determined entirely by the abrasive you use. I guess that's obvious, but if your blade isn't super duper polished, using a polishing compound is going to increase polish in the areas you use it in. In other words, you might be creating a shiny spot on your blade, trying to remove a scratch.
Brian.
