Removing Buffing Compound
Hey guys - what is the best way to remove buffing compound from creases and groves in the metal? I thought about a brass wire brush on a dremel, but thought there might be a better chemical solution. Any ideas? Thanks!
There may be better ways, but I find that WD-40 on a rag works pretty well to remove buffing compound.
Most compounds are designed to be removed with soap and water but solvents like laquer thinners or even paste wax work well.
George
Try "Fantastic"....This is a trick I picked up from a jewler.
Mace
try either a Q-tip dipped in acetone or a tooth brush with soft to medium hard bristles dipped in acetone.
Thanks guys, I got a railroad spike letter opener in the works for my wife's grandfather and the handle is quite pourous. Per your advice it should clean up real nice. Thanks again. Hoosier.
Mine sure aren't. The are a wax base. Hot soap and water won't touch the green buffing compounds.
Not to mention that we buff handle mat. also. you don't want soap and hot water much less alcohol any where most handle mat. surfaces.
I dont like using acetone because i feel it sometimes dulls the finish i've buffed onto stabilized woods and certain materials. I use 0000 steel wool and it easilly takes it off and usually will not affect any finish unless its mirror polished metal. I find the buffing compound usually sticks to the wood and the metal it can be removed with a tiny amount of elbow grease and a paper towel.
