What is the best way to remove surface grinding marks?
I have a few pieces of ATS-34 and D2 that's been precision surface ground. I've noticed that the surface isn't fine enough, how do I get it to a 600 grit finish while keeping it a "true" flat?
I tried a disc sander with a 220, 320, 400, 600 grit wet and dry paper, the finish is there -but using a pair of calipers, it varies by quite a bit in different areas.
Anyone hand rub the flats on a precision granite slab using a magnet to hold the steel? How do you do it? Grit progression? Do I need to start at 80 or 120 grit? Seems like it will take forever? Any faster methods to get a good finish, but keeping the steel truly flat?
The steel measures 1" x 4" x 1/8".
I'm making a folder and need the blade tang to be as flat as possible.
Thanks! :thumbup:
Thanks! :thumbup:
