Removing Varnish: Cabinet/Wood Scraper Vs. Spoke Shave Vs. Sandpaper
Hey guys what do you personally use to remove factory vanish from a handle?
Spoke Shave seems to be the most efficient however are expensive and need to be set up correctly to take off just what you need; somebody mentioned they aren't as easy to operate as it seems..
Cabinet/wood Scraper's seem to do a good job but what do you look for in a good scraper? There are so many makers and all with different price points to me they all look like a piece of square metal? Also another factor is having to buy a burnisher to go with it.
Sand paper is the most affordable and readily available. Can you achieve the same results with a bit of elbow grease? Other than the obvious downside of going through a lot of paper often the varnish can seep deep into the wood meaning a fair bit of work to be done.
I was looking at getting a Cabinet scrapper as it seems to be easy enough to function and can also work to shape the shoulder when hanging as well as stripping the varnish; What makes a good scraper then? I am clueless when it comes to choosing something like this. I know you can make them and a lot of you guys do but I would rather purchase my first scraper and make the next one. I have seen scrapers that cost $5 and others that cost $25 made form the same country and supposedly the same type of steel - is the quality really in the price tag or are they all much the same thing? Same goes for Burnishers I see some for $20 and some for $75.. At these prices might as well get a spoke shave and learn how to do it properly.
So what do you guys use?
Somebody said take a razor blade to the handle. I will definitely be giving this a go before I buy anything pricey.
Steel wool works pretty good, but I never tried to take the varnish that's soaked into the wood completely off.
I use a scraper, not only for removing varnish but also shaping the handle and fitting the head.
You can burnish with the shank of a drill or even the smooth round shank of screwdriver.
I’d just buy the cheap scraper.
Or even try making your own out of an old saw blade.
A well-kept piece of saw blade will strip lacquer and shape for quite a while.
You can buy scrapers but you still have to learn to sharpen/burnish them when they dull.
Scraper, all day. I use one I made from a machete tip left over from a modification project.
Yep, card scraper. A knife will also work quite well as a scraper, held at a 90. I think a thicker blade has less chatter. Sky is the limit on what you want to use for a scraper.
Very coarse (then progressively finer) sandpaper should work, but probably not the most optimal approach :).
