Replacing Axe handle but re-using the old one?
I am wondering if I could re-use my old handle once I remove it ?
Also: Should the new handle be as dry as possible or can I already oil it up for a few days/weeks/months before actually using to to replace my current handle?
Thanks !
Yes, re-using an old handle is a good idea if it's still sound. Often times old handles are slimmer and more comfortable thann new handles. They may also have larger swells than new handles.
To remove and old handle first whittle away the below the head for about 3/8". Remove just enough material to let the axe move down the haft 1/4" to 3/8". Move the axe down. Then carefully cut off the two sides of the protruding haft at the top of the axe, being careful not to cut the wedge. Now grasp the wedge in your vise or even with a pair of vise grip pliers and pull it out. You should then be able to remove the old handle safely.
See this thread:
http://www.bladeforums.com/threads/remove-an-axe-head-and-reuse-the-handle.875111/
I don't score like shown in that initial post because I don't want to create a shelf on the haft.
Re: the second question. What is the condition of your 'new' handle. Fresh from the store and covered with lacquer? Freshly carved from green or dry wood? Something else?
Uhm I just ordered it online..a Wetterlings handle...it feels dry and I believe it has darkened on the outside. So not aure how old or new it is.
Would pictures be of any help?
A new handle will have a lacquer finish. Use it as is. When the lacquer starts wearing off then sand it all off and start applying coats of BLO.
If it doesn't have a lacquer finish then go ahead and stat oiling it now. Some people like to re-hang and then finish the handle. I prefer to prepare the axe and handle separately and then bring the finished pieces together. Both ways work fine.
Hm it doesn't feel like a lacquer finish and it is not as "smooth". I can feel the wood and its uneven surface ?
Personally I like my handles to be as dry as possible when I hang. I sand away any "glazing" or wax. I like to oil them after the hang.
But any wood would go bad if not taken care of ? And like the old saying "1 day for 1 week, 1 week for 1 month and 1 month for 1 year" I would treat the handle like that before mounting it to the head... if that is okay ?
In my opinion keeping the handle dry before hanging is to your benefit. You fit it as tight as possible and then when you start oiling after the hang it will only get more snug. If it happens to dry out a bit, it will remain tight.
If you start with a swollen oiled handle and it dries out, you will have a loose head. (Dry winter air, truck heater ect)
I keep them dry untill the hang with no issues. Other people may oil before.
