I am here-are you?
How to:
1) get some GOOD clear epoxy, slow set.
2) mix it up, really well in a cheap plastic cup. I mix up probably an ounce at a time-depends on the size, of course.
3) warm it up with a heat gun-easy does it.
4) get a 10 cent "acid solder brush", sold for abour $14 a gross.
5) Use the brush to slobber the epoxy all over your handle.
6) Work it in well with the brush.
7) Add more epoxy, or wipe away with a dry brush, until it is even all over and as "wet" as you would like it.
8) let it dry horizontally-watch for pooling, bubbles or "sags" and stray brush hairs
9) Work on another knife!!!
Note: coat only one knife per batch of epoxy.
I have never "dipped" knives. Can't envision how you don't just end up with a massive mess. Maybe this is just a term, I don't know.
I demonstrated this technique at the Ashokan Knifemaking Seminar last fall-hopefully, they will invite me back next year.
Good luck,
RJ Martin
