i have both. I tend to use the half face as I can don it easier and remove my safety glasses to check my work if need be. The half face i got from Harbor Freight and it has a good seal for my face. They come in 3 sizes I believe, so you may have to estimate size and hope for the best.
No, you don't need to hope for the best
You go to a real store that is specialized in industrial safety supplies
They are certified to trial fit you for a respirator
They carry ones that are reputable and carry parts and filters.
HF and other retail stores carry no name import face-pieces and filters, but next year when the contract changes, where do you get filters for your mask ?
P100 filters
North Safety and 3M half masks
You can buy online later and the order numbers will be active for years and years.
I like the soft black silicone.
http://www.bladeforums.com/forums/s...You-Want-In-One-Place?p=12016587#post12016587
see the Safety Equipment
A half mask is 50 bucks or less
A full mask is a few hundred.
Plus the face piece will tend to get scratched up.
As for masks lasting "years and years", the valves are certified for a year, the face gasket for 2. At least that's what DOD goes by.
I didn't say that. You've got to read the words that are there.
I mean that the models are stable and consistent
You can buy parts and fittings and filters by model number because specs and part numbers are consistent year after year.
I wanted to add the reason I "hate" safety glasses is I hate them at the grinder because my particular setup has my eye about level with the belt as it's coming toward me, so when I'm looking down on the platen or wheel glasses don't really give me good protection from anything coming off the top of the belt.
I wear them all day at work for almost 20 years and generally forget I have them on the rest of the time.
I did read it. On the off chance you can actually replace the face piece (not likely) it will cost more than a new mask. So the benefit of having replacement parts on an item that is likely to reach the end of it's useful life in two years isn't really a benefit. Guess I should have pointed that out.
