- Mar 31, 2020
I recently acquired a beautiful marbles knife which I'd like to restore and use. This would be my first time doing something like this and I thought I might get some advice here.
https://imgur.com/a/UqPYJkY
The blade:
Along with removing most of the patina, it looks like someone went a put a V grind on this convex blade. I would like to restore the original grind. Would this be hard to correct? How should I go about doing it? I currently have a cheap 1000/3000 stone from amazon and that's about it.
Here's another pic of the grind:
https://imgur.com/a/cgCCSSc
The Handle:
The Handle must have dried up significantly since its pretty loose. I tried tightening the nut in the pommel and its as tight as it can be but there's still pretty significant play. Should I try and re-hydrate the handle somehow? What should I use?
A few of the spacers in the stacked handle have become unglued from each other. I was thinking of using some barge cement between them. If I'm applying some product to the handle to re-hydrate it, would it be best to apply the cement afterwards?
This pic of the handle shows the play in the spacers and the pommel:
https://imgur.com/a/041wvgT
Any advice would be greatly appreciated!
Cheers
The blade:
The Handle:
Cheers
