coloradowildman
- Oct 28, 2009
REVIEW: Fiskars X25 Splitting Axe
After my experience reviewing Fiskars excellent new X7 hatchet last year, I've been curious about the rest of the X-series line as well. Fiskars offers high value and performance at very affordable prices, making them a sure contender for the "best axe for your buck" on the market.
This particular review will focus on their new X25 Splitting Axe. I chose this particular model to test over the longer 36" X27 Splitting Axe simply because the 28" X25 is easier to control for the average person. At a homestead or base camp with people of differing heights, the 28" handle is a bit more versatile in this respect.
SPECIFICATIONS:
28" Total Length
Hardened/forged medium carbon steel head
Head weight: 4.03 lbs., Total weight: 5.42 lbs.
Country of Origin- Made in Billnäs, Finland
Warranty- Lifetime
28" Total Length
Warranty- Lifetime
As noted in my Fiskars X7 Hatchet review, the newer sheaths have been redesigned to be more robust and are meant to be a permanent sheath solution, whereas the older thinly-made sheaths fell apart fairly quickly. Note the clever new rotating orange locking knob which helps to keep the axe firmly secured:
The shape of the head has also been redesigned and lightened to 4.03lbs, compared to the Super Splitting Axe's 4.25lb head weight. The X25's cutting edge (bit) is also wider and slightly more axe-like than the almost pure wedge shape of the previous Super Splitting Axe, as shown here:
Also, as noted in the photo above, the handle on the older Super Splitting Axe used to be slightly curved at the end. The X25 (along with the entire X-series) now has a straight handle, which Fiskars claims "perfected the balance and power-to-weight ratio, increasing swing speed to multiply power, much like an aluminum baseball bat." I can't verify this claim scientifically, but from my experience testing the X7 Hatchet and the X25, it seems to have definitely improved the performance and feel over the previous models.
The X25 is now rubberized at the bottom of the handle as well, which I consider a big improvement. Vibration is reduced and it also makes it more grippy when "going for the gold" on full power swings.
Performance Testing
I wanted to test the splitting performance of the X25 using both softwood and hardwood. The first test was to split a seasoned 13" Ponderosa Pine log shown here:
The first swing resulted in a large crack and the start of a split:
The second swing easily cleaved the log in two:
Splitting the rest of the pieces was a one swing affair, resulting in a nice pile of firewood ready for the wood stove:
Hardwood Split Test
For the hardwood splitting test, I used a piece of seasoned Elm in which half the log was a giant knot, pretty much a nightmare to split. I also wanted to see how much the bit would take without rolling or chipping:
Here's a shot of the Elm from another angle right before attempting to split it:
The only realistic way for me to split this piece (which was essentially half a giant knot) was to turn it on its side and come down as hard as I could. This resulted in large crack and the start of a split from the main log:
The next swing did the trick:
The smaller piece that was split off was then set on the chopping block:
I was able to split this piece with just one swing:
SUMMARY
I'm sure there are some who will prefer the older Super Splitting Axe to the new X25, but having used the previous model at our homestead, have to say that I'm partial to the newer model and its overall feel. The redesigned head\handle, at least from my testing, appears to be an improvement in overall comfort and performance. The bit also came very sharp for an axe in this price range, another plus.
So all in all the X25 is a comfortable and well balanced splitting axe, great for the homestead, campground, base camp or wherever you need to split logs for firewood. Throw in the redesigned sheath, more comfortable and balanced handle as well as the increased performance and it combines to make this Finnish "splitter" a home run in this category. Highly recommended.
For more info visit www2.fiskars.com
