Review of Cold Steel Triple Action
WORST. KNIFE. EVER. :grumpy::barf::mad::thumbdn:
I feel pretty ripped-off after buying this knife. Cold Steel's ad copy and proof video make this knife look and sound like it's the butterfly knife updated for the 21st century — stronger, sharper and faster. It's all BS. Stick to the butterfly.
Here's what's bad about this knife:
1. The lock is worthless. It's only as strong as your grip around the handle. If you're holding or using the knife with loose fingers, the lock will constantly fail, causing the blade to fall and hack into the cover part of the handle over and over — if it doesn't hack into your fingers first. Seriously — Cold Steel loves to say that the lock on this knife is stronger than the lock on a butterfly and I promise you that's BS. The lock might have a chance of being stronger if it actually stayed in place on its own, but it's horribly unreliable and after a day or two of use it just falls open on its own. Nothing holds it in place but a tiny little nub, and the cheap aluminum wears down after just a day or two of regular use and after that the lock is worthless until you get out your pliers and tweak the frame and then it works a little for like three days, gets stuck a few times, then fails completely later.
2. That brings me to number 2, which is the fact that the knife is "tempermental". That means that for some reason the aluminum frame of this knife likes to constantly warp — just a little tiny bit — in this direction or that direction, which effects the operation of the lock. In order for the lock to click into place and stay there, everything has to line up right. But since the cheap aluminum frame can't hold its shape worth a damn, sometimes the lock clicks firmly into place, sometimes it falls open and closed like nobody even thought of putting a lock on it, and sometimes it won't open at all and out come the pliers again. Yeah, you can open this knife with one hand — sometimes. Then sometimes it takes two pairs of pliers.
3. The blade constantly strikes the cover part of the handle, unless you're really, really, really careful and handle the knife like it's a straight razor. And of course, the hollow-ground, Japanese VG-1 blade will slice a chunk out of the cheap-o aluminum handle just about every time. It also strikes the tip of the tanto blade from time to time even in the most careful of hands, so the inside of the cover looks like western Baghdad after just an hour or two of playing with it.
4. In that silly proof video, Cold Steel employees are seen handling this knife like a butterfly — opening and closing it with flashy flipping moves. I've been using butterfly knives for 20 years, so I know a little about how to get a feel for a knife. I could tell the second I got this little piece o' crud out of the box and examined it for the first time that yeah, it's easy to flip OPEN with a fancy wrist-flicky move, but try CLOSING it with a fancy wrist-flicky move and the blade will usually hit the cover and sink into it. Seriously, I've had to get pliers out once again to pull the blade's edge out of the handle cover a time or two. So I go back and watch that video again, and if you watch closely, you see that Cold Steel's knife-flippy employees are shown flipping the knife OPEN over and over. The scene always switches after the guy flips the knife open, then he flips it open again from another angle — but all the scenes where the demonstrator actually CLOSES the knife, you'll see that he does it fairly slowly so as not to damage the knife. The video does a pretty good job of making it look like the guys are flipping the knife open and closed every time, but they're not. Look closely.
5. There's no returning this knife if you open and close it even ONCE. Once you close the cover over the main part of the handle even one time, the friction between the two parts put ugly scratches on the main part of the handle. This visibly mars the surface beauty of the knife which renders it unreturnable. Even if you just open the knife and then close it and put it back in the box, you're stuck with it.
6. In the box with every new Triple Action is a set of very clear instructions, printed on bright yellow paper, that tell you how to open and close the knife using BOTH HANDS AND THE THUMB STUD. This is so they don't have to give you your money back when you inevitably damage the knife trying to use it the way they said you could use it in their promotional material. Cold Steel's ad copy and videos have loudly and clearly sold this knife as a clever new design in one-handed openers and an improvement on the butterfly knife.
7. There’s zero blade protection, but I guess I knew that before I bought it. Anyway, if you stab into anything, your fingers will probably slide off onto the blade. And this is one blade you don’t want your fingers anywhere near. I will say that Cold Steel does know how to make a blade. It’s just handles, folding mechanisms, and design ideas in general they seem to be struggling with.
Good things about this knife:
1. It’s pretty. It's the "bling" of the knife world. It’s the kind of knife you expect the flashy Miami drug dealer to have in some cheese-o vice cop movie — all flashy and big and silver. The big chrome Desert Eagle of the knife world. It’s a very visually engaging and even somewhat intimidating knife. But I don’t live in a Robert Rodriguez film, so I’m getting rid of this piece o’ crap and going back to CRKT. :-)
Feedback welcomed.
Sorry to hear your new blade is a bust bro. I'm always a little wary of 'new' technology myself. Why not send it back to the dealer and ask for a refund or credit?
If you still want a CS bali I was over at CS's website a couple of days back and they had Arc-angels going for a pretty good price./
Mark
I have to admit, after watching the infamous Cold Steel More Proof DVD, I was intrigued by this knife. I never did figure out exactly how it works, but I live close enough to Cold Steel's Ventura H.Q. that I was thinking of actually picking one up if I could find it cheap enough at their parking lot sale.
I think you've pretty much changed my mind about that. I'll have to dig out the DVD and watch the demo more closely.
I had the chance to play with a used one of these, and I ahve tom say I had the same impression...The handles were just way too light and soft...They should have used Titanium or Stainless rather than the aluminum...Other than that maybe a chnage is lock design...Its too bad because the Tri-folder design is a cool one...
Great review! :thumbup:
I was very impressed with the "Proof" video too. But you're right, they open it fast, time after time!
But close it very slow :rolleyes:
Thank you for saving me the money!!!
BETO
Sorry for my english :o
I totaly agree I own a triple action double edge.The first day I was flipping it open and closed I chiped up the vg-1 steel blade on the soft aluminum casing that tells you how good the steel is.The casing got scratched to shit, the worst investment i've ever made
The design has been around for a long time. I handled one at the CS booth shortly after they came out. The one I handled had been well broke in by the staff. It was easy to both open and close. The NIB ones were stiff and had to be open with both hands the staff said it would loosen up with use.
Personally I think the aluminum handles are cheep. Stainless steel would have been much better. The aluminum is to soft and wears to fast making it a poor choice for this application. Given the design it should be as smooth as glass out of the box with no "break" in.
Good idea poorly executed.
I think (this is just me and let me know if its the stupidest thing ever) that it could be improved upon by using titanium and instead of having a manual open for the handle making it automatic. That way, all that would be required is to push a button (opening the handle) then flip open the blade with the stud. Putting these close to each other would make it possible to do this fluidly. Also, this would make it neccesary to put a lock on the handle that is not tempermental or unreliable. A guard could also be added easily. Just an idea I had while sawing wood today :)
oh my... I just traded my Triple Action to ItchyTasty...i feel very bad now...
I bought a double edged one on a whim. I played with it for a few nights and the novelty has worn off. It is an interesting design but the execution of it is not impressive. The quality just isn't there for the price, I could've/should've bought two Ti-Lites instead....:mad::rolleyes:
Yep. It's pretty much a novelty knife, and a poorly executed one at that. If only I'd done my research a little more...
Perrin's take on the jacobs ladder pretty much blows the triple action out of the water believe me. The thing I hate most about it is when the blade digs into the Al handle--it takes a good effort to dig it back out. Don't let that CS vid wow you either--stick to balisongs for the kickass tricks.
I had to look it up in the catalogue and they are nice looking knives, but the ad copy itself conceals potential problems. First, almost half of the copy was dedicated to how neato the knife is closed. "When closed, [it] is a force to be reckoned with. It's solid construction makes it very stiff and strong.... Remarkably well suited for use as an impact weapon...serves admirably as an improvised 'Yawara' stick...secure grip which will allow the striking of powerful blows."
In fact, only the first three small paragraphs are about the knife, and the second paragraph contains mostly specs! That leaves the bulk of the copy telling us how great the knife is closed. Looking at the photos, however, it's not clear how it opens or closes.
Too bad, as they're both attractive knives. Which one did you get, incidentally? Standard or tanto?
i have an older aus-10 tanto i got for 45.00 years ago,its super sharp,& only used it for light cutting,never had any bad issues with it,maybe the early ones are better made.......
I got the double edged spearpoint model just because I thought it looked interesting and would be fun to fool with. I never had any intention of actually carrying it and using it in a serious manner. I don't think Cold Steel really intended for it to be used or carried either. The complaints are all valid ones that I agree with, but I suspect this knife was meant to be a novelty more than anything else. Just my opinion.
Speaking of novelties, I got a Smith & Wesson Powerglide which was based on the old paratroop knives created during World War II, both for the U.S. and I believe the Nazis had similarly designed versions. What all of them had in common is that they were all fairly crappy in construction. The Powerglide was unusual enough, and strong enough, that I began ordering them off the Internet at cheap prices. Okay, so they took awhile to open, they're solid once open.
If Cold Steel is going to use an aluminum exterior and not pay enough attention to the way the thing works, they ought to at least make arrangements to refund or trade the POS off for something that does work. For the price, you should get something that does work. The triple action is just another one of the Saturday Night Specials of the knife world.
Good point, Confederate. Now, despite what I said about knowing it wasn't going to be a serious user even before I bought it, I'm feelin' a bit ripped off!!:mad: I gotta see what those mercenaries over at cold steel are going to give me in exchange:D Thanks for the idea.
I wouldn't say the Triple-Action/Tri-Fold/Jacob's Ladder design is a Saturday Night Special, but as more of a obscure pattern that not many make quality versions of nowadays. As mentioned, you buy nice ones made by Fred Perrin for about $150, or production Perrin designed tri-folders at $50-$60.
And according to this thread, those "paratroop
knives" are actually a repro of a type of knife that was made in the 1950s and sold as German WWII memorabilia by frauds.
So, basically, these knives are cheap reproductions of fake antiques, sold on vague mentions of it being an issued paratrooper knife at sometime in someplace and gimmicky construction.
I don't mean to sound snippy or a know-it-all or a fussbudget, just thought you might like to know.
Edit: I can't seem to find the links to buy a Perrin trifold. Could someone more knowledgeable than me point in the right direction of a non-Cold-Steel tri-fold?
Whether authentic or not, the concept is undoubtedly outdated by now. Not that they didn't have potential, mind you. How solid were folding knives back then? I'm also amazed that Smith & Wesson would come out with a version when it seems there's no discernable reason to. Based on the thread you referenced, the originals (whether authentic or not) had a great potential to be robust. That they were not kind of belies their production. Still...still...I think every knife enthusiast should have a Powerglide! They're strong, well thought out and they make dandy toys. (My wife hates it when we've retired and are watching TV, and I'm opening the knife, inspecting it, then closing it, looking at it some more, then opening it again.)
...I don't see them being particularly easy to open one-handed. I'd hate to try to open one whilst struggling with a chute.
Actually, this design would be great for a German paratrooper. He's bailed out of his plane, anti-aircraft guns
are going off left and right, he can't see very much -- what's he going to do? He's GERMAN!!!!! So he pulls
out the knife and admires the design all the way down and he's shot!
It's a beaut of a design, it is. Get one whilst
they're still $20! Look around. They're out there.
