- May 18, 2012
If looking for a New Ultralight Multi-Fuel Backpacking Stove be sure to checkout the FireAnt which is the newest addition to The Emberlit Family. Mikhail who brought us the Emberlit launched a Kickstarter for the FireAnt ultralight Multi-fuel Stove and his project reached the funding goal in literally hours!
Now we've all seen changes in the Emberlit over the years but the FireAnt was a whole new design!
Mikhail wanted to design an Ultralight Multi-Fuel backpacking stove and I'd say he was successful! Being its made of lightweight Titanium it weighs just 2.8oz by its self or barely over 3 with the fuel plate and case. Pretty impressive.
Manufacturers specs:
Products Specifications
Material Titanium
Weight 2.8 oz
Panels 2x4.4 inches
Stove Height 4 inches
Top of stove 2.5x2.5 inches
Packs flat 1/8th of an inch
Manufactuer Merkwares
Warranty Life time
Manufacturer price $ N/A
"Quality, Parts & Assembly"
The FireAnt arrived in a padded yellow envelope direct from Emberlit.com
Inside was a black bag holding 6 pieces. 4 walls a base plate and a solid fuel tab plate.
I immediately noticed that all the pieces had a plastic film on both sides.
I suspect this film is to keep the parts protected during the stamping & shipping process. Scratches should now be minimal. I examined each part for sharp edges or defects. No defects were evident! A couple of the sides had some edges that I noticed were a little sharp but nothing razor Sharp but still worth mentioning.
Assembly is the same as the Emberlit using Locking Tabs. Fitment of all pieces were good and when all assembled it felt solid. I admit I had a smile and said out loud "its a baby Emberlit!"
It is small and really lightweight but it has lots of offerings like its able to utilize a Trangia/Esbit Type alcohol burner that fits in the slots of each wall panel. If fuel tabs are you thing the FireAnt has a Solid Fuel Tab plate that when placed in the same slits the Trangia uses sits just about an inch from the top.
The FireAnt did go through some changes like the shape of the feed port, adding a vent under it to help it burn better, Enlarging the dimples on the locking tabs ect and it shows in the quality & detail.
Assembling the stove with either alcohol burner or fuel tab plate is pretty simple. Just add the burner or plate just before you put the face plate on.
The addition of the Solid fuel tray is a great accessory many will appreciate.
"A Little on its Fuel options"
The FireAnt was intended not just to be an other Ultralight wood stove but rather Multi-Fuel stove! Alcohol burners, Solid Fuel tabs, Fuel gel or wood all can be used in the FireAnt. This means you always should be able to cook even if you forget the alcohol or fuel tabs at home ect.
"Performance"
My first burn in it was with wood! Like its big brother it started right up easily through the feed port which really handy for a stove this size. Its burn chamber is small which is the trade off for its size and will need more attention tending the fire. I filled a Canteen Cup with 2 cups of water, placed it on the FireAnt and it came to a rolling boil within several minutes. I cooked my Spicy Noodles and while eating my snack kept adding fuel to the FireAnt using only the fuel port and just watched it to see if ash or coals would be a problem on extended burns. No pot was on it. After some time feeding fuel the ash/coals did start to pile up in there but it wasn't affected much by that.
Most stoves of this type have ash/coal build up especially after using it for extended periods. Some more than others but It will depend on the end users experience with wood stoves of this type to keep things working well. There is a learning curve to using wood stoves but one can easily adapt pretty quickly!
"First test burn video"
[video=youtube_share;-gumsOno_YU]http://youtu.be/-gumsOno_YU[/video]
The Titanium turned a bunch of different colors ranging from bronze, purple to light blue which added to its beauty.
After making my dinner snack i moved the FireAnt to my little fire pit to see how it would be as a little contained Campfire. I filed it full of wood ranging from 1/4"-thumb size diameter and let it burn until the flames went out. It definitely can be a little campfire. It was now full of bright orange hot coals and I figured keep it going. I ended up loading it 3 times and each time was full until sticking out the top. I didn't clear the stove between each filling but it kept going strong. The side panels had a dull orange glow!
"Mini contained campfire test"
[video=youtube_share;3B5aYbzQSS0]http://youtu.be/3B5aYbzQSS0[/video]
I like to test every Wood stove I use this way because it really test the stove! Many things can happen doing this like warping. That's what I wanted to see. After it cooled off sighted each panel to see if any warping took place. The all panels had the usual slight curve but the front had a bit more. The burn plate had a concave to it but again normal. It disassembled and reassembled like new. I suspect it will not get any worst after burning it so hot.
Speaking of hot the heat from using it as a campfire really brought some awesome coloring to the Titanium FireAnt!
"Overall impressions"
This Little brother to the well known Emberlit with it's Simple Assembly and attention to detail performs well and Truly is a Lightweight! Yes it will require more tending the fire but thats to be expected with its small size.
I cooked, boiled water and just burned fires in it and was pleasantly satisfied with how it performed. I had no problems using wood.
The gauge of Titanium used is thinner than the Emberlit but still feels solid when assembled.
With Its being such a small light package it would be a great choice for the Ultralight crowd looking the shave every gram off their gear or definitely could be an EDC option.
Its safe to say that Mikhail Successfully Created an Ultralight Multi-fuel backpacking stove! Currently the lightest Pack flat stove in my current collection of wood stoves! A good looking one too!
For more info check out The Emberlit website at Emberlit.com
Thanks for reading and if you have questions or comments feel free to comment or contact me.
ADB
Material Titanium
Weight 2.8 oz
Panels 2x4.4 inches
Warranty Life time
"Performance"
ADB
