- Mar 17, 2010
mine is size m/l so it's 38 liters/2,319 cubic inches...i held off from buying this pack for a long time until they released this talus gray color, close enough to black for me
for 2012 they changed the logo to a round shape...the 2011 model had a semi-circle shape to it.
i'm a machete guy so any hiking pack i buy should be able to carry my 18" lite machete inside - perfect fit.
the wire frame is inside unlike my osprey manta 20...i placed the orange paracord there to highlight the wire, it's not part of the frame.
the bottom compression strap doesn't really compress the bottom though, it's just a sleeping pad/jacket/etc. strap. that zippered compartment is for a sleeping bag so the bottom straps can serve as a support as well to prevent the zippers from getting stressed too much and blowing out.
someone at osprey fell asleep on this one - the bottom straps aren't long enough to strap a commonly used thermarest foam pad.
the bushcraftusa's 10'x10' multicam tarp fits fine though (it's randomly stuffed inside it's stuff sack rather than folded neatly in this case) .
the 10'x10' tarp is too bulky to fit inside the sleeping bag compartment though.
but my o.p.s.e.c. multicam poncho and enough cordage for an a-frame shelter fits perfectly.
there's a semi-removable divider that separates the sleeping bag compartment (bottom of the pack) from the rest of the main compartment.
this is where the divider's straps is attached - one on each side.
the top lid also fits my multicam poncho and cordage with room to spare.
there's also a hidden key-hook inside the top lid.
the top lid with my poncho/shelter kit inside.
there's also lashing points on top.
the bottom side of the lid can also fit a couple of clif bars depending how full the other compartment is.
aside from being able to fit a machete inside, my other criteria is a wide waist strap. i believe the kestrel is the smallest pack with a wide belt...everything else is either 50+ liters or with a very narrow belt.
it's a pull forward design rather than away from your sides to tighten the waist belt.
perfect stitching throughout and reinforced in the stress points.
the belt is perfect for hanging my fenix pd20 flashlight and it's rigid enough that it doesn't flop around.
where i looped the belt through - it's not going anywhere.
for size reference, the belt pouches can fit about three full-sized clif bars each. also, it's actually easy to open/close it one-handed...my manta 20 requires both hands since the fabric/zippers aren't rigid enough.
the waist belt is nicely padded and vented - i used an orange paracord to show the foam and venting.
