I found these for $10, so I bought a few. Swiss Tech Utili-Key.
Price: Ten dollars US, plus 6% sales tax.
Blade Specifications: The blade is 2" long. It's a wharncliffe point, with half serrations. The blade is sharpened on one side only. Blade steel is 420J2. The right side has SWISS+TECH above UTILI-KEY on it.
Tools: Half-serrated knife. Eyeglass screwdriver. #1 flathead screwdriver. #2 Phillips screwdriver. Bottle opener. Keychain adapter.
Testing: The knife locks open at the 90 degree (halfway) point, and fully extended. The blade came out of the package pretty sharp and needed only a few minutes on a ceramic rod before it was shaving sharp. The tools all performed as they should have, except for the micro (eyeglass) screwdriver. It snapped off after three times of use with moderate pressure. There are grooves on the blade so that you can open the tool easier. The knife locks closed very securely, and has never come lose or come off my keyring. The blade cuts paper and string very well, which is about all I'd use this small knife for. I whittled a little bit, and barely dulled the blade. It touched up quickly.
This is a decent keychain knife if that's what you're looking for. It looks like a key when snapped on to your keyring. For $10, you could do a lot worse.
