Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
Just curious but it seems like gate valve and choke plate would cause the motor to work harder as well.
Restricting air flow does NOT make the motor work harder.
In fact, it's the reverse. If you reduce the amount of air the motor is moving, then you reduce the LOAD against the motor.
It's doing less work.
A shop vac is a blower - sort of - in reverse.
Put your hand over the end of the hose and the motor RPM goes up! The motor is doing less work and has less resistance so it picks up speed.
Remove your hand from the end of the hose and the RPM drops - now there's more resistance against the motor and it's working harder.
Just like closing the choke plate - as you close it the RPM increases as the motor moves less and less air.
-restricting flow increases system resistance. When fans operate against a higher backpressure, output is reduced,
When I have time I'll place an amp meter on it and see how it's affected with different air flows.
The concern that BD had was the motor operating on low voltage rather than overheating
