- Dec 1, 2016
I am really torn between a blown vertical forge or a ribbon burner horizontal forge. I'm still light years away from Damascus so that's not a big concern right now. Which would you choose and why?
Thanks!
Thanks!
I'm not sure why none of you guys don't just build "blown" horizontals, using the same type of burner that everyone uses on verticals. There's absolutely no reason that won't work, and it's quick and easy.
I guess the main reason I didn't really consider that was the perception I have from venturi fired horizontal forges, that the heating just isn't going to be very even with a single burner. Sure, angle, swirl, all that, but the verticals develop a nice even heat zone because they're vertical, and horizontals tend to have hot spots. And supposedly, a ribbon burner helps reduce that.
I built a big horizontal blown forge. It is correct that the heating isn't perfectly even across the full length. It never will be. But then if you aren't using it for HT, this isn't really a problem. If you are, then you have the same issues you always have heat treating from a forge. The blown burner still beats the venturi. I can push probably 2-4 million BTU from the burner (850CFM blower if I remember correctly), overkill sure, but there is no kill like overkill.
If you want to have a (more) even heat, do 2-3 smaller burners and "Y" off air from your blower. This route will require a bit more care as you want to get an even air flow to each burner. I tried this and found it effective but unnecessary (and like I said, you have to adjust each burner independently).
All fair points I hadn't really considered.
So, one of the current challenges I have is twists. It really sucks to do twists in my vertical. I can heat them evenly enough, but with rebar welded to them because I can't use tongs, I'm really limited to how I can twist them, and it's impossible to water quench the end with the rebar. So that's really the one thing that was forefront in my mind about needing even heat over a longer length.
Now I do realize I could twist shorter lengths etc. I was just kind of tunnel visioned on a ribbon burner being the solution to that problem. But I can think of a few ways to resolve it with a blown horizontal or multiple burner blown horizontal.
Thanks.
Same here. Great minds think alike!I have three blown vertical forges now. When - if that ever happens - I need another forge for some reason - it will be a blown vertical.
