These things allow .30 and .31 caliber rifles to shoot pistol cartridges, instead of the normal ear-splitting stuff they were originally chambered for. I've been wanting one of these for some time, and so purchased the " .32 Multi-Chamber Insert" from SportsmansGuide. For just over $20 out the door, this turned steel adapter arrives at your door, a week later. Much anticipated. (I fizzed with impatience the whole time!)
On unzipping it from its tiny baggy, you see by the paper insert that it also chambers .32acp, .32 S&W Long, as well as .32 H&R "Magnum". How a cartridge with a 21ksi pressure limit could be classed as a magnum, is beyond me. At any rate, to the review...
It just happened to fit my Post War chamber neatly, with NO extra clearance. The included literature hints that you may need to do some minor fitting (sanding the adapter) to get it to chamber easily. Do not just buy one of these, jam it into your chamber, and slam your bolt closed. If you create an interference fit, you'll be epicly and expensively unhappy. Easy does it, 'nough said.
The .32 Magnum chambering indicates that the steel adapter unit is only guaranteed for a max operating pressure of 21,000c.u.p., so hotrod handloads need not apply for this unit. People (read that "hunters") needing more power than this pressure will allow, should just skip it and reload empty rifle brass to meet their needs, conventionally.
I chose this adapter to fit a particularly good and accurate surplus .303 British rifle I hunt with. My reasoning is that I could just drop pistol cartridges into the adapter, and if they grouped well, could be made to answer for small game hunting, with less report and consequent hearing damage, to me, and to my dogs.
My first foray with some .32acp reloads proved sketchy. The .32Mag chambering with its attendant (fat) .337" chamber dimensions, meant that my short little .311" 71grain FMJ's just sorted of coasted through space, unguided, till they hit the .311 portion of the adapter, and thence into the rifling for its trip down the tube. The bullets patterned into about 4" at 25 yards, using the rifle's 500 yard flip up peep sight. A few rounds of ancient mixed headstamp factory ammo from a 50 year old box of Peters brand did better, grouping into 2" at this distance.
A check of the wooden backstop revealed that the little bullets had enough oomph to penetrate 4" of weathered pine boards and plywood. An examination of the bullets revealed that the rifling was engraved unevenly on the copper jackets --> The bullets had left the short .32auto cases, coasted through the rest of the .32Magnum chamber, and had crashed somewhat tilted (off axis) into the smoothbore portion of the cartridge adapter. No wonder they didn't group well. All their bases were tilted! Not enough to show noticeably oblong holes in the target, though.
This pattern went on for all the .32 acp I shot out of it. The velocity hadn't seemed to drop off in my 25" bbl, it's just that the accuracy wasn't there. Sound signature is directly comparable to .22LR from a rifle.
I then rummaged around in a dusty and forgotten basket, containing obscure cartridges, and located 9 pieces of empty .32 S&W Long brass, as well as a small handful of the Shorts. I ignored the Shorts.
I can tell you that after reloading the .32 Long with some 100 grain .313" Wadcutters and 2 grains of Bullseye, that I have easily achieved 2" groups at 50 yards. Bingo. This with mixed brass. I seem to see a bag of .32Long brass in my near future. The above load duplicates a standard, accurate and mild target load, but still retains a flattish 50 yard trajectory, and good knockdown power when it hits.
The same powder charge and bullet is quieter in the Long brass, than the acp brass. Ejection of the empty brass is via an abused and carboned up pencil. You're gonna want to use cast lead bullets in this application, since they have much less bore friction than jacketed. They're cheaper, too.
Here are the downsides to this cartridge adapter business:
1. .32 acp is a waste of time (solely because of accuracy considerations). Why couldn't they just make a dedicated .32auto adapter?! I'd have been happy to stop at that power level.
2. The steel unit does not achieve the usual excellent gas seal at its cartridge mouth, which we are used to from conventional brass casings. This means that a little bit of powder fouling escapes into the chamber, dirtying it, and allowing some high pressure gas to get away from the breach, making it louder for the shooter than it would have been, had there been a gas tight seal in the chamber.
3. Does not feed easily from the chamber of my No. 4 Enfield. "Push feed" is easier than CRF for this adapter.
4. Your rate of fire will best be described as "leisurely". That's not a big deal for me.
If you like interesting gizmos for your guns, this one is worthwhile. Just shoot Long or Magnums out of it.
I expect it to provide lots of quiet small game hunting hunting fun in my future, from my big game rifle.
Reloaders who cannot be bothered to mess with adding extra calibers or using fiddly adapters can roughly duplicate this performance with Ed Harris's suggested load of 5 grains of Red Dot and any 100 to 150 grain lead bullet in their .303. I've shot a TON of these low powered cartridge (approx. duplicating .38 Special or 9mmLuger power levels), but the adapter just adds an interesting new wrinkle.
I fully expect small game to flee in terror when I locate a bag of empty .32Long brass.
