The pin head spinner Stacy mentioned is good for spinning round domes on pins, and if that look is your objective, good.
If you need to spin pins to actually create a lip to hold material on like jigged bone on a slipjoint, your gonna use a different..most for sure homemade spinner. One for the heads on the handle pins(1/16") and one for the spun head on the pin in the center of the spring (likely 3/32" or 1/16"). You can make a spinner from a 1/16' and 3/32" drive pin punch that you may have broken the useable tip off from. Size of the point is important. and it should be squared off. then put it in a lathe or drill press and a small round diamond bit in a dremel or foredom, and grind a centered cup shape in the end. Try it on some pin material held in a small vice...if you get a good lip all around the pin head and material to sand/polish into a rounded dome, you have a good one.
If you have it, the Shadley /Davis book on Multiblade Folding Knives gives a good explanation of doing the pins and pics of the spinners....
By the way, I am responding because of experience.....there is alot I could confidently say I haven't mastered.....
