There's a response from Rockstead directly dealing with the choice between ZDP189 and YXR7. Taken from British Blades.....This post should help drive your decision even more....
http://www.britishblades.com/forums/showthread.php?164590-Rockstead-Advice-Needed
Re: Rockstead Advice Needed
Hi,
Thanks for the input, Im thinking YXR7 is probably the way to go ( HIGO XID ), it appears the bamboo beating that Rockstead are so fond of is usually done with this material so as long as I can keep a check on any possible corrosion this should be a better match for my needs,
Does anyone know if the Rockstead DLC coating is covered by there warranty and if it can be reapplied should it be worn beyond the scope of the cutting edge?
( Better keep it away from the ocean )
This was Rocksteads recommendation when I explained my needs ( pretty much what they say on there site )
Thank you for your reply.
I think that the YXR7 with DLC is better.
We use two kinds of steel materials for our knife-blade. The steel material is ZDP189 and YXR7. I explain the feature.
ZDP189 : This is a cutting steel that is called a powder stainless steel.
Hardness is about HRc67. After cutting Manila rope 1,000 times with this knife, you can slice paper.
However, it is not suitable to beat and cut a hard tree with this knife.
YXR7 : This steel material is a kind of high speed tool steels.
Hardness is about HRc65. You can shave your beard afterwards even if you cut and beat the dried bamboo by this knife.
It is easy to rust though this is a steel material excellent for the knife is a fault. To make up for the fault, we coat the DLC.
If you wipe the knife without fail after use, YXR7 is perfect.
Our YXR7 blade has the most slashing power, penetration power, and durability.
Please consideration about that.
Sincerely yours,
Rocksted Corporation
Noriyuki Ishida
1-26, Kannabe-cho, Sakaiku Sakai
590-0984 Osaka Japan
nori@rockstead.jp
www.rockstead.jp
