The other day I cut away some sisal/hemp rope off of a rope rug (used as a door-mat) that was fraying and tripping up people - I used my EDC Victorinox - and it was pretty unremarkable - the knife did its job fine.
But on the same evening I was idling looking at the knife and thought I could see some shiney flats on the edge.
Using a Tasco 30X illuminated microscope, to my shock, there were indeed shiney flats on the edge - enough that mere stropping would not remove them (rough side of the strop is loaded with jeweller's rouge), and I had to resort to using the fine (white) crock sticks to bring the edge back.
So was the edge of the SAK so "fragile" that a mere two strokes on some sisal/hemp rope would damage the edge?
This evening I had to do the same thing and cut away another 2 long lengths of rope from the same rug (4 cuts) - but I took them home with me this time.
I again examined my EDC SAK and, as expected, there were shiney flats on the edge.
So I test cut the sample rope I brought home with a couple of other knives to see the effect.
Kershaw Vapor - with combo edge to see how the plain and serrated edge coped, and a Gerber ATS-34 E-Z-Out to see how a premium steel would perform.
Note I was NOT interested in cutting until the blades became too dull to cut any further. I merely wanted to see with a few limited cuts how the blade edges looked under the 30x microscope.
left to right - sample of sisal/hemp rope and cut pieces; Kershaw Vapor; Gerber ATS-34 E-Z-Out; Tasco 30X illuminated microscope
I formed a loop with the rope holding with my hand and cut off a piece about 2" long. Then lay that piece on a cutting board and cut off about 1/3" pieces - ie: 5 cuts. So each blade made a mere 6 cuts.
Cutting the loop - both the plain edges made the cut cleanly. The serrated edge caught the rope and really only cut with one concave section/serration - although it did it cleanly - it did not feel as clean as the plain edges.
Cutting the section to pieces on the cutting board the plain edges did it well with sawing strokes.
The serrations points were too high for the small diameter rope to cut well - so I did not proceed any further with the serrated edge.
Looking at the edges after these minimal cuts I also saw shiney flats on the plain edges BOTH on the AUS-6A blade of the Vapor and the ATS-34 blade of the Gerber E-Z-Out.
This really should not have come as too much of a surprise - because thinking of it - that door-mat rope rug has seen years of use - as evidenced by its fraying condition - it is always very dusty/dirty - that could explain why my knife edge was damaged so quickly - the rope was most probably loaded with fine abrasive dirt/grit.
So it really didn't matter if it was Vic SAK steel, humble AUS-6A or even premium ATS-34 - the edge is going to get damaged. Although to be fair the blades were still cutting the grit loaded rope fine after a practical number of cuts/strokes that one would typically use a pocket knife for.
Any comments, similar experiences?
