- Jul 5, 2016
Looking for some input on this; I recently picked up some Ti scales and put them on a Bugout I made from a 535GRY-1 and a standard model. The bulk of the actual functional parts came off the 535 (which funnily enough, I sent into Benchmade earlier this year to repair a broken Omga spring). After the scale swap and reassembling the knife, it felt like there was some metal-on-metal friction as I could feel something rubbing. It was weird, but didn't affect the practical functionality of the knife, although it's (obviously) affected the action somewhat - it feels a lot grittier than before. Since it wasn't a major deal to me, I didn't give it much thought, but today when I took the blade apart to clean out the pivot area/blade to try and see I could lessen/eliminate some of the grit in the action, I felt the AXIS lock bar rotate around the Omega springs. There's a wear spot on the coating of the AXIS bar on the show side (LH scale side) so I slowly deployed the knife while keeping an eye on that spot and sure enough, I watched the lock bar rotate.
I'm also not saying that the moving lock bar is the cause of the grittiness, but after removing the blade and cleaning it, the pivot area, and the washers, and reassembling everything with oil, the grittiness in the action is still there so I'm not too sure what else could be causing the friction in the action.
Also, I took a look at several other of my Benchmades and didn't see any of them exhibit this trait of the rotating lock bar when deploying or closing the blade so I don't think this is normal per the other Benchmades in my collection, but I'm just looking for confirmation of this suspicion via a larger sample than just myself and the Benchmades that I have.
Video of the rotating lock bar here.
